JD 350 DOZIER WON'T MOVE
GUY
04-09-2004 07:32:12
MY DOZIER WAS RUNNING GREAT,BUT IT STARTED SLOWLY NOT TO MOVE. WHEN YOU STOP IT TAKES IT A WHILE TO TAKE OFF. ONCE IT GET GOING ITS FINE UNTIL YOU STOP AGAIN, AND NOW IT WON;T MOVE AT ALL I FIRST THOUGHT THE FILTER WAS STOPED UP BUT I CHANGED IT. PLEASE HELP
jdemaris
04-11-2004 09:22:17
 Re: JD 350 DOZIER WON'T MOVE in reply to GUY, 04-09-2004 07:32:12
Put a gauge in the reverser (I'm assuming your machine has one) and make sure clutch pressure is over 100 PSI. If not, check the clutch pedal. 350s often get debris stuck in the pedal linkage that stops it from travelling all the way, especially if the big return spring is stretched out. If you don't have a reverser, than perhaps your engine clutch is gone, or out of adjustment.
Jumpedthetrack
04-09-2004 16:51:11
Sounds like your reverser needs rebuilt.Had the same thing with my 350b loader.Right around a $3,000 price range.
Bob/Ont
04-09-2004 08:04:15
Don't know much about your JD tractor Guy but it sounds to me like the trans pump is sucking air and not picking up the oil. And with what you say the leak has gotten bigger.Check the pump suction for leaks. You likely noticed a buzzing sound coming from the pump too lately.
Later Bob
