Irv, Generally, sheet metal will swap except... the nose cone/grill assembly, if it is a loader, and it is, and they installed it correctly. The 90 loader had a pump that mounted on the front of the engine and requires a different grill to get clearance for it. Other wise the nose off a standard or utility 40 or 420 or 430 would fit (single piece grill screen). The T or W models will fit (I think) but are not correct as they have the two piece grill screen. I'm no expert but know a little bit. 40, 420, 430 metal will swap and some M metal will swap, as will other parts and if you can't find original metal, reproduction metal is available for a lot of the pieces. One tip I will offer, buy if you want it but, in crawlers, buy the undercarriage. That's the expensive part to fix. Metal and engines are nothing compared to UC repair. Just a tip from someone who's been there and wishes he hadn't done that. Loaders are hard on the UC especially the front idlers and rollers (nose heavy) and because you usually do more turning. DL
