case 310 rear end needed or oliver oc3
trent
04-13-2004 03:16:32
i have a 1965-1970 case track loader and i have cracked my rear end housing and the inside assembly (pumpkin) got destroyed , i have a new housing so i need the inside unit,whole please as i dont think mine is fixable,besides
several broken pieces and chewed gears the drum that the steering brakes contac are badly groved. i live in washington state 253-539-4783 253-536-3402 ask for trent or bruce Thank you
JIM BROWN
04-13-2004 12:22:30
 Re: case 310 rear end needed or oliver oc3 in reply to trent, 04-13-2004 03:16:32
i have a good CASE rear end with trany i will sell call me 614-402-0908 jim
Steve
04-13-2004 04:47:18
third party image
I beleive I have a brand new set of gears (ring and pinion)on the shelf that a customer ordered and never paid for. Let me check to be sure they are the correct ones. If your interested send me an email so I can reply directly to you rather than through this site.
Karen
04-13-2004 04:14:49
trent, Oliver's may looked the same and may go in there but they are NOT. Case has a much stronger brake drum. You can tell by the squared off corner on the drum where Olivers are rounded. If you compare the two you will see the Case has webing inside to support the drum. Think about it Olivers were 3200-4500lbs machines with 18-24 horsepower. Case is 5800-11000lbs machines with 42 horsepower. If you email me I will send you a link of someone that can help you
Dave Johnson
04-28-2004 12:44:46
 Re: Re: case 310 rear end needed or oliver oc3 in reply to Karen, 04-13-2004 04:14:49
Looking for 310 Case Dozer parts also, in Michigan. Need a reverse idler shaft and gears, also rear drive sprockets and top idler pulleys.
Or whole rear end assmbly.
