Model M crawler
randy baldauf
04-13-2004 04:58:26
Looking at a Model M crawler and see that the oil pan where the starter goes is broken and the the whole piece is missing along with the starter. I guess the previous owner pull started it. Anybody know where I can find a starter, and either a good oil pan or a bad oil pan with that part intact. I might be able to have it welded up. Thanks
Bill P
04-24-2004 07:42:47
 Re: Model M crawler in reply to randy baldauf, 04-13-2004 04:58:26
A lot of the A/C model m's did not have a starter, they were crank started. All of the m's had a place for a starter and they had ring gears. They are a 318 cubic inch engine, however they started real easy using the hand crank.
Joe Giordano
04-13-2004 17:23:49
Are you talking about an Allis Chalmers Model M or John Deere???? Sounds like its an AC M from what you've said.
DiggerLarry
04-13-2004 11:35:29
Randy,
I would start with Lavoy Wilcox at www.jdcrawlers.com. He's fair and honest and has a lot of stuff. If Lavoy can't help, there are some others you might try, just post back.
DL
randy baldauf
04-13-2004 19:27:57
 Re: Re: Model M crawler in reply to DiggerLarry, 04-13-2004 11:35:29
Its an Allis,
Pete
04-13-2004 19:56:40
 Re: Re: Re: Model M crawler in reply to randy baldauf, 04-13-2004 19:27:57
Try Larry Swenson at 507-787-2338. He has a lot of used AC parts.
