replacement for waukesha engine
Pete Holmander
04-14-2004 17:46:05
I have an old Michigan Payloader with a waukesha 6 cylinder overhead valve engine that is blown. I was wondering if anyone knows of anything else that might have the same mounting pattern so it would be a bolt in swap. I've been told that some of the old international truck engines are the same but I can't confirm this. I was wondering if maybe a 6 cyl chevy or gmc truck engine might fit. All information would be appreciated.
Tom Graham
04-18-2004 03:24:20
 Re: replacement for waukesha engine in reply to Pete Holmander, 04-14-2004 17:46:05
I had a Michigan 55A the had a Chevy 6 installed; I believe it was a 250 or 292. Also saw one once that had a JD engine out of a combine.
Jesse
04-16-2004 19:55:12
20V149
Heat Houser
04-15-2004 20:04:33
Many times the engines used an SAE flywheel housing. Sorry, I cannot remember the dimensions and bolt patterns but if it is SAE, the sizes and patterns were the same if you were in the same size class. i.e. SAE flywheel #2.
Try this address to see if you can match up dimensionally. Link
Pete Holmander
04-16-2004 16:36:11
 Re: Re: replacement for waukesha engine in reply to Heat Houser, 04-15-2004 20:04:33
How would I determine which size flywheel I have when the machine doesn't have a clutch. Do I go by the reverser size? Thanks for the help!
old
04-14-2004 19:51:08
I've been told that some of the chev/gmc engines will work in place of some of the. I had an old hough payloader with a chev 250 in it worked ok. You need to look close at the differant engines you may find that they are very close. Also if you have been told an IH engine will fit most of the trannys used in IH will fit up to a chev engine/bellhouseing
Pete Holmander
04-16-2004 16:41:56
 Re: Re: replacement for waukesha engine in reply to old, 04-14-2004 19:51:08
Thanks for the info.I guess I'll have to check it out to see what I have. I have a nice GMC six cylinder engine that runs sweet. It would be nice if that engine would bolt in.
J. Schwiebert
04-16-2004 18:21:03
 Re: Re: Re: replacement for waukesha engine in reply to Pete Holmander, 04-16-2004 16:41:56
What size is the blown Waukesha and where are you located?
