hydraulic adjuster
Brian
04-14-2004 19:01:55
Anyone know what causes and the fix? Hydraulic adjuster on JD 1010 grease zerks won't hold pressure- oozes grease. Figured out the check ball was missing (see- I pay attention to past posts) so I replaced that for 11 cents (who says Deere parts are high ;-)) and now I have replaced a couple zerks- they pump up ok but don't hold. Grease is coming back through the nipple. Any help appreciated.
Kelvin
04-16-2004 07:02:15
 Re: hydraulic adjuster in reply to Brian, 04-14-2004 19:01:55
I heard somebody else complain about this. His theory was that when track got under strain, pressure in the adjuster popped the ball out of the zerk. His fix was to remove the zerk and plug the hole.
Karen
04-15-2004 03:06:20
Brian, fasteddy is probably right, but if it is the cylinder I know a source for a new replacement track adjuster. Just e mail me.
Brian
04-16-2004 13:04:46
 Re: Re: hydraulic adjuster in reply to Karen, 04-15-2004 03:06:20
Thanks Karen. I see your advice alot. Are you on commission?
old
04-14-2004 19:54:42
If memory serves me right theres a check valve/ball in them and in your case its not seating right.
fasteddy
04-14-2004 20:05:53
 Re: Re: hydraulic adjuster in reply to old, 04-14-2004 19:54:42
Brian, They should not leak back on your JD 1010 crawler. Buy new fittings at your jd dealer and replace them. They will not leak then, fasteddy.
