jdemaris
04-18-2004 06:23:25
Re: Re: Re: JD 400 backhoe ??'s in reply to Larry, 04-17-2004 20:57:24
The main pump is repairable; I wouldn't replace one anymore than I'd replace a complete engine. It has two large adjustable bearings, 8 replaceable intake valves, 8 replaceable discharge valves and seats, 8 pistons and springs, and the stuff in the valve body. If you run the flow test into a bucket for the transmission pump, and you are getting some oil, then you might think about pulling the front pump and going through it. Two gallons a minute at idle speed when hot should be fine. I've seen some that once hot, pump absolutely nothing. If the pump is working reasonably well, then you can assume the main pumping part of it is okay (the pistons and their bores). If the piston bores were badly scored, the pump would be a throw-away item. Chances are you could do a good job on the pump by installing a seal kit, eight new piston springs, and maybe new discharge disks if badly worn. If you find any worn pistons, you can replace them too. ABSOLUTELY replace the stroke-control valve. That wears before anything else, and will chatter, and make the pump work intermittently. The valve can be replaced without removing the pump. There is also a cylinder shaped cartridge filter inside the valve body that should be checked once in a while. It too can be accessed without removing the pump. If you decide the transmission pump is absolutely no good, seems it must be available. I haven't worked for a Deere dealer since 1989, so I've been out of the loop for a while. That system is used in many different machines and there are all kinds of things that can go wrong i.e. and e.g. pickup pipes and o-rings failing. Keep in mind that with the Deere closed-center hydraulic system, there can be all kinds of high-pressure leaks in the system after the pump, that can cause problems and rob your oil at slow speeds, including your steering valve, selective control valve (if you have one), etc. Check your manual to see how many posssibilites there are for leaks. Usual indicator of such leaks is hard cranking and starting. My neighbor has two 4020s and one 3020, all bought new. None of them will start anymore without destroking the pumps due to internal leaks. But, the leaks are small enough that he lives with them. If he didn't have the manual destrokers, he'd be burning out starter motors every week.
