300 B John Deere
Mark R
04-19-2004 13:22:05
Machine will not engage drive when on a down hill angle (Shuttle shift) on level ground sometimes it will go and even push dirt--up hills no problem -- reverse works any time--I filled it over full with hydrolic oil --the backhoe and loader work fine--any good ideas or suggestions appreciated thanks MARK R
Jonathan
04-19-2004 14:31:37
 Re: 300 B John Deere in reply to Mark R, 04-19-2004 13:22:05
My "guess" would be a problem with the forward clutch pack in the reverser (I think its referred to as the "reverse brake" assembly in the parts book) Never have seen that happen but sounds like something that gravity is controlling and when there is a problem with these you lose forward drive power. It is a multiple disc/plate clutch assembly that gets its oil pressure fed thru a passage sealed by iron piston rings in a manifold.You have to split the tractor to access..
