Please help answer
Floyd H.
04-20-2004 10:44:59
I want to buy a crawler loader/dozer that can be pulled behind a Ford F-350 one ton single rear wheel. What are my options? What machines weigh the least ???
Karen
04-23-2004 03:43:43
 Re: Please help answer in reply to Floyd H., 04-20-2004 10:44:59
Floyd, stay 10000 lbs GVW on trailer and machine, under 18000 combined wieght. There is no way you can safely tow an 10000+ machine on a 2000+ trailer and be safe with a single wheel truck. I know some of you do this and do that but you need to think about public safety. I have seen your rigs!!! They scare me to death. Floyd, find a nice Case 310G or 350 Dozer. The loaders are heavy but the dozers are 7000-9000lbs and they are a great machine
JHesler
04-22-2004 12:22:22
You need to stay under 10,000# or away from cops unless you have a CDL. If you're over 10,000# and do have a CDL you'll need to register your little rig in combination.
JIM
04-21-2004 16:27:38
what you need is a OC3 OLIVER it is only about 5000# and will tow nice with your pickup
JD dozer mike
04-20-2004 19:53:03
I pUll my 440 with a 350 dually ford on a 16 food ,2 axle , flat bed with reese hitch.
david
04-20-2004 13:57:44
I suggest a JD 350C..It weighs about 10,000 and your rig should be able to handle that easily.
JimInOz
04-20-2004 15:38:59
 Re: Re: Please help answer in reply to david, 04-20-2004 13:57:44
Look at Mitsubishi/Komatsu...around 4 tonnes.
RexB
04-21-2004 08:59:27
 Re: Re: Re: Please help answer in reply to JimInOz, 04-20-2004 15:38:59
Second for the JD350 tow- powerful l'il dozer is a monster in the woods or grading, mine weighs right at 12K with heavy blade, rake & winch. Your trailer will weigh at least a ton too- my F350 Crew/Single pulls a 16' flatbed and dozer pretty well- but you know there's a load on. Gotta' have trailer brakes, electric/hydraulic preferably.
