JD 450 D Steering
Rick
04-21-2004 05:03:02
Novice question....My right side lever had alot of play in it compared to left side but still the machine turned. You didnt feel any pressure until you almost pulled lever all the way up. I lifted the foot plate and adjusted the right lever top linkage to sit at the same point that the left lever is when relaxed. Started machine up and track would not stop turning at all. Almost zero turning on right track. I know I need to go back other way with linkage but there will be big mismatch on where the levers are when at relaxed position with foot plate off. One last thing. Prior to adjusting the linkage, the steering seemed to get better as far as how much pull you need to turn as it warmed up and ran for awhile. What is the proper fix?
Jtilsond
04-22-2004 05:40:41
 Re: JD 450 D Steering in reply to Rick, 04-21-2004 05:03:02
Just do a search and you will find plenty on here of how to adjust those steering clutches/brakes.
