Bobcat low hydraulic waring light
Carsten
04-21-2004 12:16:22
The warning light for low transmission hydraulic came on my 773C Bobcat. I checked fluid level and replaced the filter but with no luck.
Can the drain case filters have anything to do with this ?
Is there a way to check the "sensor" ( the manual says it is some type of differential check valve ) and it looks like it is next to the filter. Any other things I can check. Everything still works but I stopped using it at the moment to be sure.
Mark
04-21-2004 15:11:07
 Re: Bobcat low hydraulic waring light in reply to Carsten, 04-21-2004 12:16:22
The low hydr. light has nothing to do with the filters. It is what it says, a low hyd level warning. Could be a bad sender on the tank,or a wire going to it pinched and grounding out which will put the light on.
Carsten
04-22-2004 07:03:47
 Re: Re: Bobcat low hydraulic waring light in reply to Mark, 04-21-2004 15:11:07
I think I found the problem last night. I wanted to check the pressure switch at the filter and when I disconnected the wire connector hydraulic fluid was dripping out. I will be heading for the parts store late.
