JD350 transmission
James
04-22-2004 05:13:09
I'm changing oil in my transmission on my JD track loader and wonder how much fluid it holds and if there is a filter and where it is located. Is JD's Hyguard a good choice of fluid or is there something better. Thanks for the help.
jdemaris
04-22-2004 05:42:52
 Re: JD350 transmission in reply to James, 04-22-2004 05:13:09
The gear transmission does not have a filter, the hydraulic reverser does. Hyguard is fine for both, or any other "combination hydraulic and transmission oil." EP 80, 90, 140W GL5 gear oil can be used in the gear transmission, but absolutely not in the reverser. Gear trans. holds about 9 quarts, reverser holds about 3 gallons, and final drives about 1 1/2 - 2 pints each.
