D6 9U steering Hyd. control question?
Michael
04-22-2004 10:34:29
The steering clutch hydraulic control mechanism leaks quite a bit, can you work on these units
and fix the leaks? or is it best left alone? Thanks for all of the information. Michael/WV
JohN 50
04-22-2004 14:08:55
 Re: D6 9U steering Hyd. control question? in reply to Michael, 04-22-2004 10:34:29
Yeah you can rebuild it, one good thing about Cat, if they built it parts can be had. Personally unless it is just something you cannot put up with I would just add oil and run it. Ran a D6 44a for years like that.
Bob/Ont
04-22-2004 17:04:30
 Re: Re: D6 9U steering Hyd. control question? in reply to JohN 50, 04-22-2004 14:08:55
Michael, you can pull the booster housing off and beseal the shafts going down to the clutch housing.
Later Bob
Michael/WV
04-23-2004 10:18:30
 Re: Re: Re: D6 9U steering Hyd. control question in reply to Bob/Ont, 04-22-2004 17:04:30
Thanks for the help, I found the brake lining for each side is 30.48. And on the steering clutch hydraulic control mechanism I found a retainer and seal for where the shaft goes in the unit for 18.39 now if it would stop raining I could finish taking the old brakes off. Later. Michael/WV
