under carrage wear
Eric
04-26-2004 09:09:44
How can you tell what percentage of wear your under carrage has. Steel Tracks
Karen
04-27-2004 04:49:06
 Re: under carrage wear in reply to Eric, 04-26-2004 09:09:44
E mail me and I will send you a link to someone that has all the spec's and will help you through the measuring.
Brokenwrench
04-26-2004 14:56:24
Undercarriage wear is calculated by taking measurements of roller diameter,idler diameter,pin and bushing wear both externally and internally,rail height, and sprocket condition and comparing them to measurements of what they were when new.Its not really something you can just look at and guess.Most track shops will check wear for you either for free if you use them to do the needed work,or for a nominal charge.
