We have a D6C and evidently used up our fuel. Anyway it appears we need to prime the system to get it to run again.We have a Maintenance Manual but the fuel bowl and priming pump appear to be different. Our fuel separator is a square device with a petcock drain at the bottom to drain out water or other sediment and another petcock at the top. It appears that we cannot obtain any fuel to run out of the top petcock. Is it necessary to prime the system to get the fuel to run out of the top petcock? In normal operations, one can open either petcock and fuel, water, or other sediment will run out of it. Also the priming pump in the manual seems to be different than the one on our D6. It appears that to operate ours one has to release the plunger by turning the plunger CCW and then pulling and pushing the plunger. Has anyone got a CAT Fuel System Priming 101 course that would assist us neophytes? Any assistance you can give will be appreciated.
