350 c question about reverser and final drive comp
trackbuilder
04-30-2004 09:07:30
350 c has a leaky reverser seal which causes oil to leak from the reverser pump to the final drive. Is there any reason why I cant just keep filling the reverser until the final drive fills up to where the oil in the two compartments is equalized. Why does there need to be a separation between the 2 anyway.
Roy Suomi
04-30-2004 22:40:11
 Re: 350 c question about reverser and final drive in reply to trackbuilder, 04-30-2004 09:07:30
Whats probably happening is the steering clutch apply oil is leakinginto the rear housing from the oil tubes and o-rings that supply presure oil to the clutches. The presure oil is supplied by the reverser. To fix , remove both final drives ,remove clutch drum, remove oil lines and inspect for blown o-ring or split oil tube
trackbuilder
04-30-2004 09:11:27
By the way, before when the final drive filled up I drained all the oil out and filled up the reverser agian. I am getting tired of doing this thus I proposed the aformentioned solution
