Rails for a JD450B
Hammerhead
04-30-2004 17:14:14
Does any body have a set of used rails for my 450B? I had a set of rollers that ive found to be bad so slacked the chains to replace them only to find a couple of links on both sides to be chewed up pretty bad like they had been twisted
tight on the side of the sprockets Ive not had this machine long and dont know the machines past life so.... Thanks Hammerhead
Karen
05-03-2004 16:24:58
 Re: Rails for a JD450B in reply to Hammerhead, 04-30-2004 17:14:14
I may know a source. Email me and I will send you his link
Mike
05-01-2004 15:23:08
You might be better off replacing the rails with new or rebuilt.You start mixing and matching undercarriage parts you are going to have accelerated wear on rollers,idlers, rails and sprockets due to existing wear patterns on old running against new. Maybe have your rails repinned and bushed,or the turned and welded up,and the bad links replaced,and new sprockets.Probably get it done for $1500 if you use aftermarket parts.
