2010 dozer
Joe
07-10-2001 05:57:15
I'd like to find some info. on the 2010 crawler, weight,hp,how good or bad were they etc. Any help would be appricated. Thanks
S.J.D
07-23-2001 12:48:44
 Re: 2010 dozer in reply to Joe, 07-10-2001 05:57:15
To:Joe:From:SJD.If your talking about the JD.2010 series crawler tractors with the 2000 series Engines and winches,they were about 65hp diesel class,with very close fits and tolerances if you wanted to rebuild the engines.They came after JD's440 series and preceded the JD 450 series with about the same hp.They had good hyraulics with inboard or outboard blades.Engines were good and the roller,truck,undercarriges were simple and easy to repair.One fault on the rollers though was that they had zerk fittings that needed oil often and the rollers didn't have seales bearings.Had one from about 1967(used)to about 1980.The 2000 series hyraulic JD winches were crapp.Hopes this helps you.SJD.
