JD450 Transmission Cooler Lines
Jathen Lee
05-03-2004 08:12:35
I Have A JD450 Loader With A Leaking Transmission Cooler Line. How Do I Remove It ????
Disconnected Both Ends But Steel Line Won't Move
Please advise
jtilson
05-04-2004 05:36:08
 Re: JD450 Transmission Cooler Lines in reply to Jathen Lee, 05-03-2004 08:12:35
You have removed the tubing to frame clamps along the frame up near the nose, haven't you? There may be several and you may have to bend and twist the tubing some. I replaced mine with hose cause you cant get them back in. Guess I will wait until an out of frame overhaul or clutch replacement.
Its hard no matter how you do it.;
Steve
05-03-2004 10:36:56
third party image
They are impossible to remove without removing the hard nose and belly pan first. Even then they are extremely difficult to get out. They are sandwiched between the frame and the clutch housing to frame spacer.
