H-3 CRAWLER
robert wells
07-10-2001 15:22:17
I NEED A MOTOR FOR A-C H-3CRAWLER MINE HAS A CRACKED BLOCK AND A BROKE ROD CAP WHERE IT TURNED IN THE CAP
hector gemme
02-10-2005 13:08:44
 Re: H-3 CRAWLER in reply to robert wells, 07-10-2001 15:22:17
HI I HAVE SOME HD3 USE PARTS
H-3 Fan
07-10-2001 20:18:03
Robert if you can't find a H-3 engine, you could use the block from a AC D-15 tractor. The only difference that I can remenber is that tractors didn't use fuel pumps, crawlers did. They also made two gas engines prior to S/N6959 that would be a G-149 aprox.43hp and S/N 6959 & up would be a G-160 aprox.52hp. Roughly 1965 is when they changed to the bigger engine. But the tractors changed too. So you can widen your search and better your chances. Good Luck!
