McCormick Deering Crawler
JDAOS
05-03-2004 18:11:46
Trying to start a McCormick Deering four cylinder Gas Diesel crawler. Need firing order and how to time Mag. Thanks
king of obsolete
05-04-2004 19:41:44
 Re: McCormick Deering Crawler in reply to JDAOS, 05-03-2004 18:11:46
lots of ih talk on redpower, check it out----http://redpowermagazine.com/cgi/yabb/YaBB.cgi?board=news----- thanks
Bob/Ont
05-04-2004 17:58:54
I think it's 1342 but you can check with the valve cover off for sure. Then get it set with #4 valves rocking, #1 TDC. Watch the direction of rotation of the mag drive as you turn the engine over clockwise facing the front. Then turn the mag in it's direction of rotation untill the rotor points almost to #1 on the cap. Install the mag with the bolts loose and rotate the mag against it's shaft rotation untill it clicks and lock it up there. The rotor will turn opposite shaft rotation as it has a 2:1 gear reduction.
Later Bob
JDAOS
05-04-2004 19:01:58
 Re: Re: McCormick Deering Crawler in reply to Bob/Ont, 05-04-2004 17:58:54
Thanks Information appreciated.
Bob/Ont
05-04-2004 19:26:48
 Re: Re: Re: McCormick Deering Crawler in reply to JDAOS, 05-04-2004 19:01:58
Your welcome, I am working from what I know about them from the distant past. I believe the Diesel engine turns the mag in the oposite direction to a Gasoline engine. But this will help you work with what you have to get it right.
Later Bob
