serial #CAT D6 dozer
Pam
05-05-2004 08:15:23
I have this serial number for my CAT D6 dozer. It is 4H5891 then beside it there was this RENAC. Can anyone tell me what year this dozer is? Thanks!!
SCJim
05-11-2004 21:11:47
 Re: serial #CAT D6 dozer in reply to Pam, 05-05-2004 08:15:23
Hi Pam! Not sure about that number either. Maybe 1 of 2 things: 1. If the tag is on the engine, it is the engine sn. 2. (my bet) If the tag is on the machine, it could be a military machine. Think I've seen 'RENAC' before, but can't remember what it means. Haven't dealt w/many of these older tractors. Your Cat dealer has a technical service department that should be able to help you trace it down. Hope that helps!
Jim
Tommy D6-8U
05-08-2004 14:17:59
Hi Pam,
Tommy here from SC. That number seems like a part number instead of a serial number. The only serial numbers that are close are a 2H series made between 1935 and 1941 and a 4R series made between 1941 and 1947. Where did this number come from? The serial numbers will be stamped into the engine and rear end cases on most tractors. Part numbers are generally raised numbers in the various castings. I hope this helps.
Tommy
Pam
05-10-2004 07:57:20
 Re: Re: serial #CAT D6 dozer in reply to Tommy D6-8U, 05-08-2004 14:17:59
The numbers are off a CAT D6 Dozer and not a tractor. Does this help?
Tommy D6-8U
05-10-2004 19:54:54
 Re: Re: Re: serial #CAT D6 dozer in reply to Pam, 05-10-2004 07:57:20
Pam,
What I was asking (wasn't clear was I!) is where on the tractor/dozer did the number come from. On my D6-8U, the serial number is on tags, one on the left side of the engine block near the starting engine or starter and one on the rear of the transmission/rear axle main case just below the seat and fuel tank on the rear face of the housing. If the tags are gone, the number is stamped into the block or housing. I think the other series tractors are similar. I have a good bit of info on the 8U and 9U series and I can find out about most others. Hope this helps.
Tommy
Pam
05-17-2004 12:01:14
 Re: Re: Re: Re: serial #CAT D6 dozer in reply to Tommy D6-8U, 05-10-2004 19:54:54
I have 2 different numbers I found. The first one is 7U42035 (track type) and the second one is 4H9275 this was found on the plate on the back of the dozer. Does this help. Thanks!!!!
