td-6 motor I D
ray
05-06-2004 14:24:08
I would like to know what motor is in my td-6, model no. 6k3 serial no b-3050. thank you Ray, ps I need a oil pan
ray
05-08-2004 17:17:31
 Re: td-6 motor I D in reply to ray, 05-06-2004 14:24:08
I found the serial no. it looks like td62 667 or td62 067 undre that it has 1800 rpms thank for the help ray
gm
05-07-2004 23:04:40
I have one for the gas start diesel version. -Greg
ray
05-09-2004 04:53:00
 Re: Re: td-6 motor I D in reply to gm, 05-07-2004 23:04:40
greg what do you want for oil pan.what area are you in. thanks ray
gm
05-09-2004 20:49:46
 Re: Re: Re: td-6 motor I D in reply to ray, 05-09-2004 04:53:00
$75, Its not too heavy so can ship where ever. email me and we will work it out. -Greg
ray
05-10-2004 15:13:36
 Re: Re: Re: Re: td-6 motor I D in reply to gm, 05-09-2004 20:49:46
greg can you measure the oil pan and count the bolt holes, what area are you in , ray
gm
05-10-2004 22:39:52
 Re: Re: Re: Re: Re: td-6 motor I D in reply to ray, 05-10-2004 15:13:36
if yours starts on gas, then its the same pan. I can measure though. email greg@supercgis.com -Greg
Milton
05-07-2004 07:49:48
Hello Ray, --- 7 / May / 2004 ---
The SERIAL NUMBER that your giving - is that the motor SERIAL NUMBER or the Chassis Serial Number ? The Chassis Serial Numbers would have Prefix Letters ""TDBK" or "TD6 / 61" or "TD6 / 62" . What does the SERIAL NUMBER TAG read -
International Harvester Company / Chicago, Ill. -
or International Harvester Company / Doncaster, England ? Regards, Milton
wheatland47
05-07-2004 17:30:01
 Re: Re: td-6 motor I D in reply to Milton, 05-07-2004 07:49:48
I believe the TD-6 motor and the MD motors are the same.
sibby(Aus)
05-08-2004 23:07:19
 Re: Re: Re: td-6 motor I D in reply to wheatland47, 05-07-2004 17:30:01
Wheatland47, Are the engine sumps (oil pans) the same, i have a feeling the cross spring for the td6 bolts onto sump, could be wrong as we sold ours over 20 years ago, sump felt like it weighed half a ton on the crawler.? cheers, sibby.
