Carb adjustment
polk crawler
05-07-2004 06:48:05
Have a TSX 403 carb on my crawler but have not been able to find directions on how to set the two adjustment screws; setting throttle adjust screw is easy but no success with the other two screws; crawler starts but smokes a little at start which suggests improper screw adjustments.
Appreciate any advice and thanks.
PC
RK
05-11-2004 15:09:01
 Re: Carb adjustment in reply to polk crawler, 05-07-2004 06:48:05
PC, I don't have a 403, but do have a 641, and a 245. Believe adjustments would be pretty much the same. With engine at idle, turn idle adjusting screw clockwise "in" til engine begins to falter or roll (too rich). Then turn same screw counter clockwise "out" till engine begins to falter or roll from leanness. Turn the screw clockwise "in" approximately half way between these two positions til engine runs smooth. Now the load adjustment. Turn load adjusting neddle clockwise "in" to fully closed position, then turn counter-clockwise "out" about one and a quarter turns. Operate engine under load, if it misses or looses power, turn needle out 1/8 of a turn, operate under load again, if it still looses power, turn out another 1/8 turn, and so on. If she's pushing black smoke under a load, neddle is out too far, and will have to be turned clockwise "in" 1/8 of a turn at a time til you have full power without the black smoke. Hope this helps. RK
