JD 440C Right brake stops both tracks
Daniel Moeck
05-16-2004 15:09:30
Does anyone know what might be causing this problem on my JD 440C? I have done the steering lever travel and syncronizing adjustments and the left side works fine. But over a period of several hours of use the right brake began stopping both tracks. I see a broken spring dangling near the bottom of the left clutch. But since the problem developed gradually I don't see how the broken spring could be the only problem. Any way to avoid tearing the whole machine apart to fix it?
Lavoy
05-16-2004 15:58:22
 Re: JD 440C Right brake stops both tracks in reply to Daniel Moeck, 05-16-2004 15:09:30
There are a few different scenarios, but most likely is that the right track is stopping, and the left side clutch is slipping when it has to cause the turn.
Double check your left clutch adjustment.
Lavoy
Daniel Moeck
05-16-2004 18:33:55
 Re: Re: JD 440C Right brake stops both tracks in reply to Lavoy, 05-16-2004 15:58:22
Thank you very much, Lavoy. That did the trick.
