The D6-9U was another model by Cat that lived up to Cat's reputation, whether a dry clutch or a later oil type. I think that if kept in adjustment and properly operated (meaning you're not riding the clutch or running it with your hand on the lever with it not snapped over center partially engaged all the time) it should last you. Get the servicemans reference book, and parts manual for it, so you can read up on the operation and maintenance. I think ( don't quote me ) that when running and the tractor is stationary for a length of time, your main clutch should be left engaged and your transmission + forward reverse levers in neutral. Have to check the book on it, when running the pony to start you want it disengaged and all levers in neutral. I had a dry one (still not sure what happened) on my D7 overheat & go up in smoke last Aug. This one is a true low hour machine, the linings looked thick prior to, clutch brake needed adjustment, and there seemed to be some noticable vibration when running prior to it letting loose, which I'm inclined to believe was due to age, got the upper bellhousing ready to hoist out and to be honest, even though I've never done one of these, I'm sure I'll get it done, I took the exploded view diagram from the book and magnified it on the copy machine to make it easier to read, it does not look too complicated,( I've got to finish it soon ) little time consuming, have heard of people taking them apart and re-assembling or adjusting them in a couple of hours, I would not worry too much about it, that 9U should serve you well if you read up on it and give it thorough maintenance, ( take good care of that pony, keep the oil changed in it and do not run it if the oil ever gets thinned by gasoline, change it out - few other pony tips that are good to know like it needs the main to spin for coolant to circulate through the pony so don't run it for too long without spinning the main, also draining the carb. bowl or letting it run out of gas by shutting the valve from the tank so the bowl is empty and cannot leak down into the crankcase etc. ) I have habit of warning people about pony motor care, did see one toss a rod once, so don't mind me, sounds like a great find I'd quickly hand her the money and give it the same care as the orig. owner did.
