Proper adhesive for HD-5G input shaft seal boot
RO
05-18-2004 16:05:11
I've been unable to get a consensus from service persons about what kind of adhesive should be used to glue the neoprene boot assembly of the mechanical oil seal at the transmission input shaft of my HD-5G. The original service manual says to use "neoprene cement". I've had difficulty finding "neoprene cement" and three different AC service shops have given me different information. Logically, with new parts and everything clean, I want to do the job right.
Does anyone know what I should use?
jdemaris
05-19-2004 05:38:42
 Re: Proper adhesive for HD-5G input shaft seal boo in reply to RO, 05-18-2004 16:05:11
I don't know what an engineer would tell you, but I'd use some room temperature vulcanizing compound. I've used it for years on similar applications and it's never failed me as long as all is clean when you apply it. Use the red though, and not the blue - I've had many problems with the blue stuff.
