T 20 Engine Service/overhaul manual
Morris Baumgart
05-18-2004 21:45:14
Guys,
I am in desperate need of an overhaul/service
manual for my T 20 engine. I searched all the normal sources, been watching E-bay for 6 months,
and I can't seem to find anything. I think that an F 20 engine overhaul manual is the same...
Does anyone even have a manual that I could 'rent'
(I give a deposit of $50, by check or MO, copy the overhaul manual, and send it back? I'll pay shipping both ways, plus some for the privilege) Any ideas or help would be appreciated...
Morris Baumgartner
Rough & Ready, Ca. 95975
JerePa
05-19-2004 16:49:08
 Re: T 20 Engine Service/overhaul manual in reply to Morris Baumgartner, 05-18-2004 21:45:14
Why didn't you ask your old buddy? I have the manual-Servicemans Guide for Model U 7 power unit & T-20 & F-20 engines. Form C3722. Binder Books has them. If they are out, I'll copy mine. Hows that for service. There is also an engine guide put out by Thompson that lists most of the early crawler engines plus tractors & trucks. Jere
Mo
05-19-2004 18:50:57
 Re: Re: T 20 Engine Service/overhaul manual in reply to JerePa, 05-19-2004 16:49:08
Jere,
I thought you probably read my post about the "T 20 Motor, Froze up???" on RPM. Anyway, I have the 'Servicemen's Guide', but it only shows adjustments, no assembly stuff. If ya could copy
yer T 20 Engine Service/Overhaul Book, I sure would be greatful... Figure out what it costs to copy it, and how much to mail it, and I'll send you a MO for that amount; I don't expect something fer nothing!!!! More to come on the Frozen Motor, I'm doing the head and valves next.
Thanks a whole bunch,
Mo
king of obsolete
05-19-2004 14:15:49
t-20, keep us posted on this, was the=is engine used in any tractors????? ? thanks
Morris
05-19-2004 14:35:01
 Re: Re: T 20 Engine Service/overhaul manual in reply to king of obsolete, 05-19-2004 14:15:49
Hey King, I need this Engine Overhaul/Service Manual for MY 1932 T 20... Got any ideas?
T 20 or Mo
T 20 or Mo
05-19-2004 14:40:31
 Re: Re: Re: T 20 Engine Service/overhaul manual in reply to Morris , 05-19-2004 14:35:01
King, I think the T 20 engines and the F 20 engines were/are the same...
T 20
Bernard le mécano
06-14-2004 08:03:53
 Re: Re: Re: Re: T 20 Engine Service/overhaul manu in reply to T 20 or Mo, 05-19-2004 14:40:31
Hi, a friend of mine, look for a T 20, with stuck engine and broken manifold. Is that engine was in late or early tractor model or not? He think that the 10-20 or 10-35 was the same. Have you a source for parts, like pistons and rings and gaskets? Thank you. Bernard le mécano Québec Canada
moseed
07-28-2004 16:55:54
 Re: Re: Re: Re: Re: T 20 Engine Service/overhaul in reply to Bernard le mécano, 06-14-2004 08:03:53
The McCormick Deering 10-20 and the Farmall Regular have many parts that will swap. The F-20 replaced the Regular however I'm not so sure as many parts will swap as with the Regular and the 10-20.
