Manual for a JD 350 Crawler - fnial drive problem
Rob J
05-19-2004 12:25:43
Looking for sources for a repair manual. I have pieces of a JD manual but it's missing the final drive and that's our problem.
Any tips on the problem? I haven't had time to tear it down (lots of work there). Started making a banging noise on the left side. Won't move. Steering clutches were getting weak but still ok just before. This sounds worse. Also it jumped the track a couple times and I noticed the sproket was angled toward the front(IE not in line with the front sproket). When I used the blade and blocks in the back to bang the track back on the sprocket did not seem loose or anything. While going from forward to reverse and the changes in the load the sprocket never moved. Prior to this the track was never a problem. Any thoughts?
thanks,
Rob
Ed Tucker
05-19-2004 16:58:33
 Re: Manual for a JD 350 Crawler - fnial drive prob in reply to Rob J, 05-19-2004 12:25:43
Rob, Give me a holler, I can fix you up with an affordable Service Manual and Parts Catalog if needed. Ed Tucker SE Indiana
