Case CK Back Hoe
Dale
05-20-2004 05:44:30
Would Like To Talk To Somebody About The Shuttal Trans. Like What The Thickness Of The Disk's
Should Be Etc. Or Some One In MN. That I Could
Have Them Look At This Part.
The Tractor Wont Move At All, Now It's All Apart,
What Do We Look For On The Converter & The Clutches.
The Clutch Pack Has About +1/8 Gap When You Push Them To One Side.
Dale
05-22-2004 08:01:05
 Re: Case CK Back Hoe in reply to Dale, 05-20-2004 05:44:30
Thanks for your help; AJ
I started to take the bolts out to take the comverter out & felt around the bottom & there
was something loose, It was the bypass valve from the pump, well Daaaa, No pressure to the shuttle,
do you think I should take the converter apart & check it over? Were there any problems with them?
Is there a thickness to the plates where they are no good? They look good.
AJ
05-22-2004 10:18:18
 Re: Re: Case CK Back Hoe in reply to Dale, 05-22-2004 08:01:05
I don't think there is any point taking it apart and I am surprised if you can as they are usually a sealed unit,The valve will have been the trouble,I dont know the specs for the discs but if they look good and were working ok before I would put them back.
Good Luck
AJ
AJ
05-21-2004 17:46:11
Carefully examine the spline in the torque convertor,it is unlikely that the forward and reverse clutches failed at the same time,if it stopped driving in both directions suddenly it is more than likely that the spline has sheared.
AJ
