streeing clutches on a td6
colt
05-20-2004 07:51:50
Ok I have 2 td6's here trying to restore one. I have removed the clutches from both and went to order up clutch kits. Here is the problem I have found one td6 has big springs inside the clutches and the other had no springs inside.
I believe that the springs should be there, but I am not sure which one was right as I have not got a manual yet.
Could someone give me which is right or wrong or did make a change between a 51(52) to a 54.
colt
05-20-2004 07:55:21
 Re: streeing clutches on a td6 in reply to colt, 05-20-2004 07:51:50
Oh one other thing if you can not answer that at the parts store I was told to check the right casing for a # starting with 501 for them to get me the right parts ordered up. I looked everywhere right side left side and I found no #.
If you know where this # is located that would be a great help also.
Thanks
captain crunch
05-20-2004 21:39:22
 Re: Re: streeing clutches on a td6 in reply to colt, 05-20-2004 07:55:21
Colt There should be a tag on dash above Compression release(Gas starting lever)with tractor serial # on it.Check out Red Power Mag Forum several TD-6 people over there.
