need a rebuild kit for idler adjustment rams IH 50
Dave
05-21-2004 17:29:20
I have been having fun pushing dirt around with my IH 500 dozer, but one of the idler adjustment rams is leaking grease out the seal around the piston. Does anyone have a source for a rebuild kit? It works ok as is but I want to fix it right because the track will loosen up with use.
ben brown
05-21-2004 19:18:13
 Re: need a rebuild kit for idler adjustment rams I in reply to Dave, 05-21-2004 17:29:20
dave ther are only a coulpe o-ring in the adjuster here is the part number you need 2 of 378 726R1 washer o-ring back. up need 2 of 464 048 R1 o-ring plungsr bar, and 1 of 675 140 R1 ring plunger bar wiper thies are or look to be common type o-rings
TIM HIBEN
06-12-2005 17:44:21
 Re: Re: need a rebuild kit for idler adjustment ra in reply to ben brown, 05-21-2004 19:18:13
HI BEN , JUST WONDERING IF YOU HAPPEN TO KNOW OF A LEFT FINAL DRIVE FOR A IH 500E.CASTING #852518C1..THANKS TIM
