HD5G Stiff left Brake
WayneB
05-22-2004 07:54:30
FYI
Parked crawler for 8 months.
Had to: Pull and replaced starter, lube service.
Left brake while adjusted correctly was stiff, barely worked. Turned out to be, the fuel return line fitting weeped down onto housing, and wet brake drum. Tank was still nearly full fuel. Though.
Tightened fitting. Anyway: Removed top brake drum plate --can of brake cleaner, and back into business in 25 minutes. Works great now.
