420C steering clutch
Bernie in MA
05-25-2004 17:58:02
The bottom end of the rod that connects the lever to the throw bearing broke off. I can still use the crawler by backing up to turn. Am I apt to damage someting else to keep using it? The steering lever jiggles when the tractor moves.
Jim in michigan
05-26-2004 20:37:55
 Re: 420C steering clutch in reply to Bernie in MA, 05-25-2004 17:58:02
Thats what mine was acting like before th final drive went, the lever was jumping and then it broke... Jim
Bernie in MA
05-27-2004 06:50:09
 Re: Re: 420C steering clutch in reply to Jim in michigan, 05-26-2004 20:37:55
I've been using mine, so far so good. Everything works and sounds ok, I just can't disengage the clutch. Have to back up to turn. I'm making a road thru the woods so I can get to where I'm enlarging the field without having to wait until the hay is cut.
Lavoy
05-27-2004 09:18:45
 Re: Re: Re: 420C steering clutch in reply to Bernie in MA, 05-27-2004 06:50:09
Be careful, if the broken piece happens to hit the pressure plate as it is turning, it could jam some stuff up.
Lavoy
