350B Reverser is ill
GT
05-26-2004 15:37:12
My reverser on a 350B loader (1974 - 4,000 hrs.)will do absolutely nothing if there is a lot of dirt/motion resistance. IE: I shift from 2 to 3 with clutch in, release clutch, then push reverser handle forward - nothing...other than the feeling of torque. If I go back to a lower gear like second and try again it works fine. This is true for any gear, any time the reverser goes from nuetral to forward (or reverse) when there is measureable load resistance. Time to have the reverser rebuilt??
jdemaris
05-28-2004 07:06:34
 Re: 350B Reverser is ill in reply to GT, 05-26-2004 15:37:12
You ought to check the main clutch pressure first, and make sure the accumulator/stop bolt in the control valve didn't get screwed up, or the "rate of shift" screw turned in, or the clutch pedal is returning fully and the big spring is still good, etc.
Steve
05-27-2004 10:15:09
third party image
Sounds like it. If you need parts shoot me an email directly.
