woven brake lining
keno
05-26-2004 18:22:00
Need a source for woven brake lining.
Anyone bought any lately?. keno
Wayne
05-26-2004 20:14:47
 Re: woven brake lining in reply to keno, 05-26-2004 18:22:00
You might try Capricorn brake out of Louisiana. We've been getting the folded and compressed lining from them to reline bands for a customer that's still draglining with a 9570 Northwest. They are the by far cheapest place we've found to get that particular type of lining and I recon they'll be the cheapest for the plain old woven stuff as well. I'll get their number tomorrow when I get to the shop and post it for you back here.
Billy NY
05-28-2004 19:06:46
 Re: Re: woven brake lining in reply to Wayne, 05-26-2004 20:14:47
Here's there info,(Link Below)
Capricorn Brake L.L.C. 1125 Avenue Du Chateau
Covington, LA. 70433
(985) 875-0102
Seems like a good place to try & see if they could re-line the driven & driving cones on an old LeTourneau power control unit used for a cable dozer & scraper.
Wayne
05-28-2004 20:05:16
 Re: Re: Re: woven brake lining in reply to Billy NY, 05-28-2004 19:06:46
Hey Billy, thanks for following up for me. I got called out of town yesterday and didn't back in til late this evening. Wayne
Billy NY
05-29-2004 06:17:20
 Re: Re: Re: Re: woven brake lining in reply to Wayne, 05-28-2004 20:05:16
No problem, thread caught my eye, as I've been curious to see if anyone deals with the old type linings and or might be able to re-line clutch cones. Worth a call to find out.
Wayne
05-30-2004 22:30:29
 Re: Re: Re: Re: Re: woven brake lining in reply to Billy NY, 05-29-2004 06:17:20
Hey Billy, if the linings you have are riveted on then we can do them for you with no problem. We're right outside of Charlotte, NC, near the Lowes Motor Speedway. If their bonded, etc and if Capricorn can't do it maybe CECO Friction in Landis, NC can do it. We were going through them to get all the lining we use til we found Capricorn and alot better prices. I know CECO can actually manufacture brake bands custom or to match a patern, do bonded/glued type linings, etc etc. I don't have their number in front of me but if you want it, or if your bands are riveted and you just want a price to get them done, write me at Nota55Nomad@AOL.com
Billy NY
05-31-2004 05:03:47
 Re: Re: Re: Re: Re: Re: woven brake lining in reply to Wayne, 05-30-2004 22:30:29
No problem, not ready to tackle the project right at the moment, but I will print this out for future reference as I will have to deal with these linings at some point in the near future.
I've got LeTourneau power control units on both my D-7's, old obsolete double spool cable units to operate the dozer & or a cable scraper. They require a little tinkering, adjusting but other than the clutch cone(s) facings, brake band facings not too much else seems to go wrong with them, so for orginality it would be nice to keep them on both machines. I've got one in good original operating order with low hours, and another that will need a tear down, and most likely facings replaced.
Fortunately I have the books on them, the cones are concentric in shape and to re-line them you must press on the new lining tightly to a tapered steel cone, then rivet the facing to the cone. Also need to use a lathe to take down any high spots ( for metallic facings ) prior to assembly, metallic facings need to have a 15 deg. taper ( I assume this is the same taper on the steel cone which the facings are attached to. If metallic facings are put on in segments onto the cone, just have to make sure the taper is correct and equal around the circumference and that they are tightly adhered, otherwise the clutch will feel spongy. They were either manufactured with woven facings and also metallic facings. There are details in the book regarding re-lining which I could possibly scan & forward prior to and or with an order I also have a spare cone that could be looked at to see what could be done, it's not in great shape, but all there.
There are quite a few of these type of units still in use by antique caterpillar owners, and I do not know of anyone as of yet who could re-line these cones correctly, if it can be done, I'm sure others may want to have cones re-lined to preserve their LeTourneau units instead of having to replace them with the later Caterpillar ones, so there may be a small market out there for this work.
keno
05-27-2004 19:26:05
thanks Wayne that would help me alot. Keno
