d69u can't figer'; no fuel at injector lines.....
denjoe
05-27-2004 17:23:57
changed the 4 fuel filters, cracked bleeder valve, ;cracked lines,had fuel at injector lines (ones at bottom of injectors not on top) plenty of fresh fuel in tank. Suddenly, no fuel coming out of lines. I pulled the inspection plate and the 6 pumps are working. I have cracked every line coming out of this thing. If I loosen the top plate that houses the filters there is pressure. Gaskets are properly aligned. This beast has been sitting for 4 yrs. Finally got the pony running pretty well. Engages fine. Sure would like to start this ol' dozer and I feel like if I can get fuel to her she'll start. What the heck is going on????? ??? Thanks!!!
Bob/Ont
05-27-2004 18:27:14
 Re: d69u can't figer'; no fuel at injector lines.. in reply to denjoe, 05-27-2004 17:23:57
Denjoe, did you have the fuel on when you cranked the engine over?
Later Bob
youngster
05-29-2004 07:03:28
 Re: Re: d69u can't figer'; no fuel at injector lin in reply to Bob/Ont, 05-27-2004 18:27:14
just keep tracin lines. start at tank does it go into pump. yes or no. if filters are after pump or \have a scaveging pump make sure all that is moving. yes or no. is it goin into pump. yes or no. is it all just goin back through the return line. if it is try blockin it off. and go from there
Jerry
06-29-2004 20:06:27
 Re: Re: Re: d69u can't figer'; no fuel at injector in reply to youngster, 05-29-2004 07:03:28
your fuel rack is stuck on off, when you shut off a old cat motor after it stops open the throttel
