AJ
05-31-2004 04:09:11
Re: Case 580K Backhoe in reply to Randy, 05-30-2004 19:58:33
Rotten luck Randy,I am in the UK and have fitted glass to many a 580K,the only place I could ever get the glass from is the Case dealer,the door glass is easy to fit as it is drilled and held on with hinges,the curved piece is bonded,you have to clean off all the old glass and adhesive,use an old wood chisel and make sure you leave no small piece behind that could break the new glass,when you get the new glass you need to get a tube of adhesive,it comes in a cartridge,you will need one of those cartridge guns to apply it,put about 5/16" bead on the cab about 3/4" in from the edge,place the new glass up against it in the correct place and firmly press it into place,I usually put a rope through the back window and side door to hold it in place,the adhesive will squash out but don't touch it,leave it till it sets and trim off the excess with a sharp knife,if you try to do anything with the adhesive when it is soft you will end up making an awful mess,protect your hands as it is sob to get it off,the Case part no for the door glass that opens on the left side is E48359,the left curved glass is E48351, Good Luck AJ
