d6d jumps out of gear
Bud
06-02-2004 11:17:24
Direct drive D6D short stick(shuttle) jumps out of gear under load. Shift interlock or shifter fork problem maybe or $$$$$$overhaul/replace/oh sh#@$%#$! time? thanks
Bob/Ont
06-02-2004 12:57:52
 Re: d6d jumps out of gear in reply to Bud, 06-02-2004 11:17:24
Bud, to check the interlock, try to move the lever out of gear with the clutch engaged with the engine not running. The lever shouldn't move from the gear it's in untill you disengage the clutch. If it does then adjust the linkage from the clutch lever to the interlock. Come on back with what you find.
Later Bob
Bud
06-03-2004 17:53:26
 Re: Re: d6d jumps out of gear in reply to Bob/Ont, 06-02-2004 12:57:52
Probly just the linkage. Its pretty sloppy. I'll tighten er up and see how it does..thanks
Bob/Ont
06-04-2004 18:44:41
 Re: Re: Re: d6d jumps out of gear in reply to Bud, 06-03-2004 17:53:26
Bud,Take the linkage off and move it untill the interlock holds the lever in gear. Then adjust it the length to put the pin in with the clutch lever engaged. Likely pin wear etc.
Later Bob
