Case 590 Turbo Help
psudo-farmer
06-04-2004 05:47:39
Hello all! I am hoping someone can point me in the right direction here....it's an iformative place.
I have a Case 590 Turbo w/extendahoe. The problem is this: After about 10 minutes of running, the brake pedals get tight (like brakes are locked) the loader will not freewheel, just locks up. You can let the hoe sit for a couple of minutes and it will loosen up a little. After a minute, it's back to locked up. After a few minutes of this, the engine gets hot, the tranny starts to take a few seconds to engage and move.....time to shut it off.
It seems like the e-brake is getting stuck. We have adjusted the e-brake to loosen it up.
Anyone reconize this problem? I hope someone here can point me in the right direction.
Thanks for looking.
alrman
06-07-2004 02:33:16
 Re: Case 590 Turbo Help in reply to psudo-farmer, 06-04-2004 05:47:39
Your brake pedals require 'free play'- some slight movement before the master cyls are activated.Before you adjust the push rods check the stops on the pedals which control their heights - they sometimes come loose & adjust themselves up & prevent oil returning from axles.
CHEERS
