Isuzu engine adapter
Bob
06-05-2004 14:13:09
I would like to find the parts to install a hydraulic pump on a 4cyl Isuzu engine . I have a Lull 1800 skid steer that has a Vickers pump.
I have a good Isuzu enigne from a Luv pickup but none of the parts from the original setup to mate the pump to the engine. I would like the parts to use the Vickers pump or or a different pump with the parts to mount it to the back of the Isuzu engine.
I have contacted General Motors and Vickers and neither has provided any information.
I would appreciate what ever anyone knows about getting this skid steer together . Thanks , Bob
arvid in wis.
09-29-2005 12:29:09
 Re: Isuzu engine adapter in reply to Bob, 06-05-2004 14:13:09
I need vickers hydrulic pump for lull 1800 or the number on the pump.
KEVIN L
07-09-2004 19:37:39
BOB WAS READING OLD POSTS ON YTMAG IF YOUR STILL LOOKIN, LAST FALL I WAS AT THE LOCAL TRACTOR SALVAGE YARD AND THEY HAD A JD SKIDSTEER(OWATONNA) WITH A DIESEL IN IT THAT HAD BEEN IN A FIRE. AS FAR AS I KNOW THEY USED THE ISUZU DIESEL IN THAT UNI. ALL WAS COMPLETE AND THERE JUST BURNT, MAYBE THE HOUSING IS OK? THEY ARE CALLED DOWNING TRACTOR PARTS, PART OF ALL STATES AG PARTS INC PHONE # 1 877 530 1010 LOCATEDIN DOWNING WI GOOD LUCK KEVIN LENK
Bob
06-06-2004 21:52:39
I should add that Bobcat, Gehl, Mustang and others also use Isuzu diesels and I would like to hear if anyone has information of parts or even salvage units that might be available . I am located in Iowa. Thanks , Bob
Brokenwrench
06-07-2004 12:16:55
 Re: Re: Isuzu engine adapter in reply to Bob , 06-06-2004 21:52:39
While the manufacturers use Isuzu engines,it may very well be a different series with a removable bellhousing adapter.Most of the Isuzu diesels in skids use an industrial bellhousing.Does the bell housing adapter unbolt from your engine?You can try GD Equipment in Shippensburg,Pa.717-530-0170, they have some salvage skids and might have parts. Have your engine model,size, series and whatever other numbers you can find off of it. If your engine doesn't have a removable plate on the rear,I would guess you are out of luck as you have an automotive block,and an industrial adapter can't be mounted.
Bob
06-07-2004 20:32:26
 Re: Re: Re: Isuzu engine adapter in reply to Brokenwrench, 06-07-2004 12:16:55
Thanks for the reply . The bell housing does unbolt from the block . I don't know if there are adapters for a pump that will bolt on the block, but I do know that there are SAE standard patterns that manufacturers use for interchangeability of applications.
I also talked to a local skid steer dealer who said he would not recommend using an engine from a pickup truck because of a different power curve needed for skidsteer use and he said that they had one which had such a swap that they had traded for and they planned to replace it with the correct engine. Some time later I contacted them to see if I could get the adapter that and parts that they had taken out. They told me that when the unit came in they used it and decided the pickup engine worked just fine and they decided not to change it. While this did not get me any parts it did make me believe that the swap is possible.
