MF recoil spring
Steve
06-06-2004 17:45:24
I need so information on the recoil spring set-up. When I removed the track on my 200B, to replace adjuster seals, it appears that the recoil spring isn't set correctly. The main rod has a square head on the rear end that seems that it should fit into the square space in the frame but... it isn't that way now. I assume that the springs need to be compressed by turning the hex fitting at the front where it mates to the adjuster piston. The question is: is this right and if so, how do I set the spring to proper tension? Thanks is advance. Tip
