Darren, I'm pretty new to crawlers too, this past winter I bought my first machine. I also considered a "toy dozer" or a small machine, because they do have their benefits/advantages. But after analyzing what I wanted to do, I decided I'd rather pay a bit extra and get a larger machine with enough reserve power/weight to much more easily do what I needed to do. I figured I might break an older small machine struggling to dig big stumps out of the ground, and would essentially be unable to push down big trees like I can with a bigger machine. I have a 15 acre heavily wooded lot that I needed to cut an 800 foot driveway through, log out a BUNCH of storm downed trees on, and clear my building area etc. I decided to get an old (1969) International 150 Drott loader (weighing about 21,000 lbs with ~75 hp diesel engine). With the exception of a ruptured hydraulic line early on, this machine has been fantastic. TONS of reserve power, trees/stumps don't have a chance when confronted with this loader. And it will doze and dig big piles of dirt really well. Plus this machine really wasn't that expensive ($8000) when compared with a lot of much smaller and less capable machines I found that were in comparable condition. And Im pretty sure if I was willing to wait around and hunt for a bargain, I probably could have snagged a machine like this for a few thousand less. What it boils down to is to carefully analyze what you want to do and be sure to take into consideration what type of soil you will be working in. Where I live the soils are very soft, silty clay-like material with almost no rocks. I would be better off with a wider tracked machine for that reason, but as long as it's relatively dry out, this machine works fine. But if the pond you want to dig has stumps, and is in hard soil with lots of rocks...do yourself a BIG favor and stay away from a smaller machine. Either have a professional come out and do it for you (which usually is the best bet), or opt for a bigger machine. Remember that these old machines are just that, OLD. Better to get more machine than you technically need, and work it less so that it doesn't break on you. If it breaks, that pond will become a serious money pit and a huge headache! Good luck...
