fireline plow parts
Lavoy
06-08-2004 20:44:44
I am going to be working on an old fireline plow, I believe it to be a Seico (not sure of spelling). I am giong to need some parts, but this is a tool that we do not have in this area. Anybody know if they are still in business, or any other ideas?
The plow was on a 40 John Deere, so is not a large plow.
Lavoy
Charley
06-15-2004 06:20:01
 Re: fireline plow parts in reply to Lavoy, 06-08-2004 20:44:44
Glad to hear someone is working on a Sieco plow. Worked for the Missouri Department of Conservation and we had Sieco plows on crawlers. Last I knew the company was still in business. We modified them a lot to work better in our rocky soils. Not many parts would have to come from Sieco, other parts can be made to work with some welding and cutting. Where are you located?
Lavoy
06-15-2004 08:56:24
 Re: Re: fireline plow parts in reply to Charley, 06-15-2004 06:20:01
I am in SE ND, not much for fireline plow around here.
Any of the steel parts I am not worried about, but I do need the moldboards, and a new hub and coulter if I can find it. THe hub can be made, and the coulter is not that big of a deal, but the moldboards are. Any idea how I can get in touch with Seico?
Lavoy
paul kelley
06-11-2004 21:27:08
HELLO: Lavoy - I don't have a darn word to provide you on your plow problem, but I thought you might like a response of some type - so being's that I havn't said HOWDY in a LONG time I figured I would here - SO HELLO - up there in GODS COUNTRY !!!!! (P) Good LUCK on you plow -
P.S. - Still running the JD350 with left turn ONLY !!! It is such a GREAT little machine I just can't seem to find the time to tear it down - you know we never really get a WINTER it just COOLS off a bit !!!! OH - by the way - do you loose all of the fluid when you change the reverser filter - the book really does NOT give a hint !!! ??? I would like to get it changed - common sense tells me YES - but I know you would know !!! Thanks (P)
Lavoy
06-15-2004 08:58:39
 Re: Re: fireline plow parts in reply to paul kelley, 06-11-2004 21:27:08
Yes, it is going to dump the oil, but that is not such a bad deal, as long as you are replacing filter, might as well change the oil. Good to here from you.
Lavoy
