How many TON Puller
Chris
06-10-2004 09:54:24
I am probably goint to end up doint he final drives and seals on my 955H myself...does anyone know what size puller I should need for pulling the sprockets.
Bob/Ont
06-10-2004 10:06:52
 Re: How many TON Puller in reply to Chris, 06-10-2004 09:54:24
Chris, the 70ton rod out/50 ton rod in cyl with ears to attach the 3 links is the best one to use. Have you pulled any Cat sprockets before? There are a few things you should know before you start if you haven't. Email me if you like.
Later Bob
Chris
06-10-2004 10:43:39
 Re: Re: How many TON Puller in reply to Bob/Ont, 06-10-2004 10:06:52
This will be the first ones...believe me I am not happy about it. I just got a qoute from Cat to bo a rebearing and reseal with no major parts ...5000.00 Thats crazy!!! I tried to email you but I don't know if it worked. You can always email me direct on this post...I put the hide function off. Anyway any advice would be helpful.
Bob/Ont
06-10-2004 12:15:34
 Re: Re: Re: How many TON Puller in reply to Chris, 06-10-2004 10:43:39
I didn't get it but I shot you one back to put in addressbook. It's a lot of work doing a rebearing but you can split the difference if you can't get the right tools. It's a bit trickey to do but once you get the track and frame off. Pull the outer holder off of the deadshaft, then you can unbolt the case from the tractor and get them to press off the sprocket install the inner seal and press it back on and tighten up the nut. You should change the hub bearings anyway. They take a lot of load especially the outer one. When you get the machine blocked up the track off and the frame out of the way I will tell you more.If you get the machine blocked up high enough the frame can be rolled up the track out of you way. Make sure the blocking is solid and stable.
Later Bob
Chris
06-11-2004 05:52:36
 Re: Re: Re: Re: How many TON Puller in reply to Bob/Ont, 06-10-2004 12:15:34
If the weather clears up...I plan on starting on her this weekend....I was reading the service manual and I have a plan...we'll see how well it works. I'll let you know how it turns out..I'm sure it will make some interesting reading.
Bob/Ont
06-11-2004 18:13:52
 Re: Re: Re: Re: Re: How many TON Puller in reply to Chris, 06-11-2004 05:52:36
Read it over good and look at the drawings so you understand how it's put together and adjusted Chris. Then you will understand how to take it apart and why.
Later Bob
