TD-14A International crawler precombustion chamber
Kenneth Bounds
06-10-2004 16:37:48
I need a set (4) of precombustion chambers for the head on a TD-14A International crawler tractor. I purchased a good used head that had the precombustion chambers removed. Does anyone out there have or know where I can get these items
JerePa
06-13-2004 10:25:33
 Re: TD-14A International crawler precombustion cha in reply to Kenneth Bounds, 06-10-2004 16:37:48
Did you find the precombustion chambers yet?
JerePa
06-15-2004 13:07:26
 Re: Re: TD-14A International crawler precombustion in reply to JerePa, 06-13-2004 10:25:33
Just did a search at FP Smith. Search said they had new & used ones (56291D) in stock.
Kenneth Bounds
06-15-2004 08:01:17
JerePa: No, I havn't found any yet. I called FP Smith Parts and Equipment and they need a part number which I don't have. Parts there said they might match the cups if I can give them a number off an injector or the injector housing. I havn't gone out to get one of the injectors yet to see if I can find a number. So, the answer to your question is No. Even if I find a number they still may not have the chambers to match. If you have any ideas on the matter please let me know. Thanks KB
JerePa
06-15-2004 13:02:08
 Re: Re: Re: TD-14A International crawler precombus in reply to Kenneth Bounds, 06-15-2004 08:01:17
Precup part # is 53616 or 56291. Either number will work. FP Smith has a page you can do a search on with part numbers. You may also want to try Weber Tractor parts. He has alot of NOS stuff. If you can't find any, let me know. I will ask my friend if he can find any. Jere
Fred Cook
06-10-2004 18:07:25
F.P. Smith 1-800-55-tractor.There in Northern
California. They have it all.
Kenneth Bounds
06-15-2004 08:11:50
 Re: Re: TD-14A International crawler precombustion in reply to Fred Cook, 06-10-2004 18:07:25
Thanks for your input Fred. The 800 number you gave me seems to have too many numbers. I did find a number for F P Smith Parts and Equipment. That number is 800-210-1122. Parts there said they need a part number (which I don't have);but said they might match the chambers to any numbers I can find on the injectors or injector housings. So, as soon as I can get out to get one of the injectors I'll look for a number and hopefully they can match it up. Thanks KB
Fred Cook
06-27-2004 08:54:07
 Re: Re: Re: TD-14A International crawler precombus in reply to Kenneth Bounds, 06-15-2004 08:11:50
I call that # alot it works in California,try
red power magazines web site. Someone there will
have the part #.
