MF recoil setting
Steve
06-11-2004 12:04:32
I have cleaned and reconnected the adjuster sleeve to the rod and tensioned the recoil springs. The only question is how much pre-load should they have? Can anyone tell me how much pre-load and how to gauge sufficient? TIA, Tip
Steve in SJ
06-11-2004 17:51:03
 Re: MF recoil setting in reply to Steve, 06-11-2004 12:04:32
External Spring
length of spring free 455mm (19.67") ,mounted 341mm (13.42")
corresponding load, 4435KG (9780lbs)
hope that helps
Steve
Steve in VA
06-12-2004 12:12:39
 Re: Re: MF recoil setting in reply to Steve in SJ, 06-11-2004 17:51:03
That certainly should. I also received a set of measurements from Jim in Oz so I should be able to torque to those specs. Thanks much. Tip
