580K stalling
Alex
06-13-2004 07:46:59
Looking for help on this one. My 580K will start and run fine when cold but once it's warm if you shut it off it will start again run for 5 seconds then die. After 30 seconds of turning over it will fire up and run fine until you shut it off again. All the filters were chainged recently. Anyone ever have this happen to them?
AJ
06-13-2004 12:50:34
 Re: 580K stalling in reply to Alex, 06-13-2004 07:46:59
Make sure that the fuel tank is vented and not causing a vacuum,check the lift pump is not allowing fuel to flow back,check the lines are not drawing air,make sure the tap on the tank is fully open and not blocked.
Good luck
AJ
