Case 580c Neutral interlock specs?
Jeff
06-13-2004 18:49:14
My 580c on has the neutral switch on the floor,
and my machines I use at work have neutral interlocks on the bucket control.
So I'm going to make an addl switch and mount it on my bucket control, but I needs the specs
on the neutral switch. I know its 12v, but
what kind of amperage draw does the neutral solenoid take?
Jim
06-14-2004 20:07:04
 Re: Case 580c Neutral interlock specs? in reply to Jeff, 06-13-2004 18:49:14
Jeff, the solenoid wont take much amperage, and switches are cheap. It's probably 1A at the most. Get a switch rated for a few amps and you are safe. you can get a feel for how much by looking at wire size going to the solenoid. To be exactly sure, just put a multimeter current clamp on on of the solenoid leads.
Jeff
06-15-2004 16:48:25
 Re: Re: Case 580c Neutral interlock specs? in reply to Jim, 06-14-2004 20:07:04
Yea, I was trying to avoid having to grab
my inductive amp meter... :)
