jdemaris
06-16-2004 19:34:52
Re: Re: Re: JD 350 Reverser replacement in reply to Ed, 06-16-2004 13:23:36
I have seen that happen many times with reversers put together wrong. General joke about in the shop with "rebuilt" reversers was . . . either it won't make it one day, or it WILL last for years. I've seen quite a few that didn't last ten minutes. Main problem is the getting the bearings too tight. I don't believe the orifice in the shaft got plugged from grease. More likely the bearings were too tight, and the middle bearing is the weakest link being the smallest, and it got trashed. Unlike other types of gearboxes, the reverser bearing preload cannot be set by "hand" or "feel" for several reasons. One important reason being that there will always be sideplay in the imput shaft no matter how tight the bearings are. Some people assume that as long as there is sideplay, there is endplay. NOT TRUE. When the reverser is put together with either new or good bearings, a few shims should be added (temporarily) to the rear bearing quill to avoid the possibility of crushing the bearings. Then tighten everything up. Put the reverser upside down (with the input shaft pointing down). Get the case to rest on some wood blocks or equivalent so the end of the input shaft is not touching the floor. Then, take the pipe plug out of the rear bearing quill and put a dial indicator in it. Then, pry up on the input shaft from the floor while measuring endplay at teh rear with the dial indicator. It kind of a pain but it is the ONLY way to do it right. Get things set with .002"- .004" endplay and you'll be fine. I suspect the last person who rebuilt it had a heavy preload/crush on the bearings instead of end-play and that's all it takes to burn it up, quick. Especially the older 1010s and early 350s with the smaller center bearings. But, I've seen plenty of the later or updated ones with the larger bearings get trashed too. By the way, my 1010 has over 10,000 hours on it, it' never been apart, and it has the small center bearing assembly. Make sure your torsional isolator (or dampener plate) is okay, and make sure the reverser has good lube pressure when you get it going (stick a gauge in it).
